T1 check
lepavelcisco
T1 check
hi,
i have 2 sites connected by 2 t1's through a converter
ROUTER<---->converter(RAD IMAXI-4)<--------->2T1's<------------>converter(RAD IMAXI-4)<---->ROUTER
i seem like i am not getting 3MB bandwidth as i supposed to get.
i want to make a sterile test, disconnect the routers and instead connect 2 pc's (i case i have some problems with the config) on each site
PC<---->converter(RAD IMAXI-4)<--------->2T1's<------------>converter(RAD IMAXI-4)<---->PC
now:
1. is the command "PING 1.1.1.1 -l 3000 -t" good reference to check that the that the T1's OK and i am getting 3MB bandwidth?
are the PC really generates 3MB packets and sends them?
how is ,packet wise,the ping command on PC works?
Is it a good reference?
2. What programs can i use to test that the T1's OK and i am getting 3MB bandwidth?.
3.Let say i don't have programs to help me, what kind of testes or checks (with my PC ) can i do to see that the T1's OK and i am getting 3MB bandwidth? (like downloading a file from one PC to another).
6 Replies 6
avmabe
Level 3
Level 3
hi,
any more ideas?
iperf is indeed the most immediately available tool for bandwidth measurements.
OK,
i am on vacation as soon as i get back i will try it in my lab.
but for now i need something simple, to guide someone to use it.
hi,
i tried to use IPerf.
and i am kind of lost.
let say i have 2 PC's in MY LAN or i put 2 PC'a from each side of a T1, and i want to see what is the maximum bandwidth i have in each direction how should i config the iperf or Jperf to do TCP and UDP check and what results should i expect?
Joseph W. Doherty
I like TTCP since it behaves as a TCP flow should but pushes to max rate. Also I like that you can use Cisco routers as a sink (if you send to the TCP discard port [if enabled]).
