Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
T1 configuration
have two 1841 routers trying to set them up and test before deployment at the end of T1 point to point. this is my first T1 work need help. I have the T1 as showing up with line protocol down. what kind of cable would I need in a test environment to get them to communitcate?
Re: T1 configuration
this is for rj45 connection? a regular crossover would not work?
thanks
Hall of Fame Super Silver
John
The connection looks like rj45 but a "regular" or Ethernet crossover will absolutely not work. A T1 crossover is significantly different than an Ethernet crossover.
Rick
Hai,
What is the type of interface is it a V.35 interface you can check using DCE/DTE cabling.
You should use the same encapsulation bothe end.(one interface shoud be DCE and other interface shoud be DTE)
if its an G703(E1 Controler) interface cable should be made in such a way TX Pair shoud Go to RX,RX Pair should go to TX
TX ----------------- RX
RX ------------------ TX
Hope this helps
Correct me if i am wroing guys
ujil
hai,
Pls find the attached cable back to back connectivity cable colour coding.
ujil
184
