T1 DSU/CSU compatible
Does anyone know if the T1 DSU/CSU card is compatible with a VWIC-2MFT-T1? We are going to use it as a data t1.
1 ACCEPTED SOLUTION
Re: T1 DSU/CSU compatible
Yes.  I've tested this in my lab but with a homemade t1 xover.
Are these devices going to be at the same location? I'm just curiuos as to what excatly your doing, that's all - don't mean to poke..
Hall of Fame Super Gold
Please state the exact part number and on which router model you intend to use it.
The new card is a WIC-1DSU-T1-V2. The WIC-1DSU-T1-V2 will be in an 1841 and the VWIC-2MFT-T1 is already in a 2821. Can these two cards interface with each other? Standard RJ48 T1 cable?
data point to point t1 in seperate physcial locations.....slow i know.
That all depends on the bandwidth and the amount of traffic going across. If you need help or configs to set this up let me know.
Good Luck..
I have a few other P2P T1s configured but just not with this particular card. thanks for the help.
685
