T1, FT1(56/64k), T3 interface config?
Can somebody please tell me where do I find a complete guide for interface configuration?
I'm in Telecom bussiness.
Thx
1 REPLY
Bronze
Re: T1, FT1(56/64k), T3 interface config?
If you installed a new CT3IP or if you want to change the configuration of an existing controller, you must enter the Configuration mode. If you replaced the CT3IP that was previously configured, the system will recognize the new CT3IP and bring it up in the existing configuration.
After you verify that the new CT3IP is installed correctly, use the privileged-level configure command to configure the new CT3IP controller. Be prepared with the information you will need, such as the following:
T3 information: for example clock source and framing type
T1 information: for example clock source, line code, and framing type
Channel information and timeslot mapping
Protocols and encapsulations you plan to use on the new interfaces
Internet protocol (IP) addresses if you plan to configure the interfaces for IP routing
Whether the new interface will use bridging
105
