Webcast-Catalyst9k
T1 PRI
I check the cisco 1800 product and it support T1 PRI
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_setup.html#wp34472
Any idea if I buy two 1800 boxes and phase out the AS530. pls advice
rdgs
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: T1 PRI
T1 config is the same. For most uses, the voice features will be the same.
Please remember to rate useful posts with the scrollbox below.
Re: T1 PRI
It can be done, for data calls only.
Or keep a single box (28xx), less administrative work.
Re: T1 PRI
does 1800/2800 support voice calls?
rdgs
Re: T1 PRI
For voice calls, the 1861 and the 28xx do support that with VWICx-xx-xxx.
For modem calls, you need a 2811 as minimum, with HWIC-1CE1T1-PRI and PVDM2-xxDM.
Re: T1 PRI
one more question, is the config of 2861's T1 pri the same as 5300's T1 pri config? which voice feature(s) 2861 does not support?
rdgs
Re: T1 PRI
155
