T3 Circuit with NM-1T3/E3 card is not working
I have a clear P-to-P t3 circuti through AT$T, both routers and their Ser 2/0 are configured exactly the same
Current configuration : 3107 bytes
version 12.4
hostname xxx
boot-start-marker
boot system flash:c3845-advipservicesk9-mz.124-16b.bin
boot-end-marker
card type t3 2
logging buffered 51200 warnings
enable secret xxx
no aaa new-model
ip cef
ip domain name equitymethods.com
voice-card 0
no dspfarm
crypto pki trustpoint TP-self-signed-3555988581
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3555988581
revocation-check none
rsakeypair TP-self-signed-3555988581
crypto pki certificate chain TP-self-signed-3555988581
certificate self-signed 01
xxx !
controller T3 2/0
clock source line
cablelength 70
interface GigabitEthernet0/0
ip address 10.10.30.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial2/0
bandwidth 44210
ip address 10.20.50.1 255.255.255.248
dsu bandwidth 44210
ip default-gateway 10.20.50.2
ip route 0.0.0.0 0.0.0.0 10.20.50.2
ip route 172.16.200.0 255.255.255.0 10.10.30.2
ip route 172.16.255.0 255.255.255.0 10.10.30.2
ip http server
no ip http secure-server
control-plane
ORLNDMESA001#sh controller t3
T3 2/0 is down.
Applique type is Subrate T3
Receiver has remote alarm.
MDL transmission is disabled
FEAC code received: No code is being received
Framing is C-BIT Parity, Line Code is B3ZS, Clock Source is Line
Data in current interval (80 seconds elapsed):
0 Line Code Violations, 0 P-bit Coding Violation
0 C-bit Coding Violation, 0 P-bit Err Secs
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs
80 Unavailable Secs, 0 Line Errored Secs
0 C-bit Errored Secs, 0 C-bit Severely Errored Secs
Total Data (last 1 15 minute intervals):
0 Line Code Violations, 7 P-bit Coding Violation,
0 C-bit Coding Violation, 0 P-bit Err Secs,
0 P-bit Severely Err Secs, 0 Severely Err Framing Secs,
900 Unavailable Secs, 0 Line Errored Secs,
I know the clocksource says "line" but I was grasping I changed it back to internal and both routers (3845's with NM-1T3/E3 Modules) are exactl;y the same
On my cards I have an "AL" light amber and my "FERF/RAI" light is amber
If I disconnect the cable and place a connector in and loop back the cable at one end my alarm lights go off at the distant end
Re: T3 Circuit with NM-1T3/E3 card is not working
Nevermind, I found the problem
Just curious, what was the problem?
713
