04-28-2008 11:38 PM - edited 03-03-2019 09:44 PM
My customer told me that T3 line has many CRC error during day.So I checked my configuration,
the config like below:
card type t3 1
controller T3 1/0
cablelength 10
interface Serial1/0
description From Seoul To Chung do
bandwidth 44210
ip address 10.40.250.1 255.255.255.0
dsu bandwidth 44210
In Controller T3,the cablelength related the CRC error? When I miss configuration length?
and dsu bandwidth 44210 configure in just one side? or not both configured?
Solved! Go to Solution.
04-29-2008 06:59 AM
Under your controller T3 1/0 type in the command "clock source line". This should eliminate those CRC errors.
04-29-2008 12:02 AM
To configure the "Card Type and Controller" for T3 you need to follow the following "SUMMARY STEPS"
1. enable
2. configure terminal
3. card type t3
4. controller t3
5. framing
6. cablelength
7. clock source
8. exit
NEXT
To configure DSU Mode and Bandwidth for T3 ou need to follow the following "SUMMARY STEPS"
1. enable
3. interface serial
4. dsu mode
5. dsu bandwidth
6. exit
are you covered all? Thanks Goutam (Pls rate if I am informative)
04-29-2008 06:59 AM
