T3 error
My Fluke Optiview Wan analyzer keeps sending me this error..."Description: DS3/E3 Alarms detected: DS3 DTE Alarms exceed threshold : 1 contiguous alarm seconds (threshold=1)" . This is on a Frame Relay line on one of my WAN Routers. I've done the show Frame LMI and PVC commands and other than one DLCI showing unused and active, nothing else seems out of the ordinary (it apparently has been like this a long time). Service to my distant end nodes seems to be ok. I've been getting this error since at least last Friday. Are there any other commands I can try to get to the root of this problem?
Re: T3 error
C'mon! Somebody's got to have some idea!
Re: T3 error
Could it be something to do with the DS3 controller itself? Do a show controller and look for errors?
HTH,
Sundar
Silver
Re: T3 error
To look at alarms and erros for a DS3 interface you can use: 'show controllers serial ...'
Hope this helps. If so, please rate this post.
Brad
Re: T3 error
I did the show controllers serial and it reports 0 alarms.
Re: T3 error
It appears that the alarm stays on for a second and goes away. This is why you can't see it when you do a show controllers serial. I guess you have to catch it when it is actually occurring.
Silver
Re: T3 error
The only way to get to the root of this problem is to display the controller for the T-3. This will show you any layer 1 alarms that are occurring. From this point you can determine what is happening. From your descriptions it shows DTE alarms, Since the DTE is built into the card, possibly the T-3 card/module is faulty. Your service is up/runnig with no issues except this alarm I would watch it to see what happens or open a TAC case and have the card swapped out....
204
