Community Member
T3 framing issue
I have a Cisco 2821 with a t3 controller which currently has the framing set to c-bit. My provider needs for this to be either turned off altogether or set to bypass. Bypass is not an option and when I try "no framing" it still shows it as being set to c-bit.
Anybody have any suggestions for a way around this?
Thanks.
1 ACCEPTED SOLUTION
Community Member
Re: T3 framing issue
You need to configure it as an E3, not a T3. The framing for an T3 is cbit or m13, where an E3 is bypass or g751.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a008020eced.html#wp1064838
Community Member
Community Member
That's great, thanks for your help. I'll have to talk to my provider to see why they want T3 with bypass!
119
