You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
T3 links
Wwe are currently in the process of taking a T3 point to point connection. My question is we have a 2811 router where we would install the T3 network module, would the cisco 2811 be of a good specification to handle the traffic used on this link.
Many thanks
  • WAN Routing and Switching
Silver
Re: T3 links
If you are just going to perform normal packet switching with CEF turned on you should be fine. The 2811 can handle 61 Mbps of throughput.
Re: T3 links
yes, but a 2811 only support SUBRATE T-3 service.. meaning you wont be able to fully utilize the line, or from what I remember use it more than 20mbps. the serialization takes a hit on the box, so the earlier bigger quote may be for straight ethernet to ethernet only....
Better off getting a 3825 which can fully utilize the line...
try this link
http://www.miercom.com/dl.html?fid=20040903&type=report
269
