TACACS Important
aneesh.ts
I was configuring tacacs authorization for a cisco router. Device got blocked now. I cant enter any commands now. Its throwing the error message "Command Authorization failed"
i want an option to get the device up and working now. box is 3750.
Amit Singh
If config is not saved, Please reload it so that it comes back without TACACS config.
This error is related to AAA authorization not being enabled on the switch.
When you try to config again, Please also put a fallback mode to local authentication and authorization. What would have happened is that you have only enabled authentication with the AAA authorization. Please enable authentication along authorization.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/configuration/guide/swauthen.html#wp1044243
HTH,
-amit singh
Amit Singh
HTH,
-amit singh
