TACACS Problem .....
Please help me for this problem
we have a PPP Link .End A 7206 and End B 7206 router.we are implementing the TACACS services on the router B. and tacacs server is residing in router A end. it's validates only tacacs user when our link is proper b/w END A and END B router. we want router should be validate also local user as well as TACACS user.
the configuration is following....
aaa authentication login default local group tacacs+
aaa authentication login NO_AUTHEN none
aaa authentication ppp default group default-group local
aaa authorization console
aaa authorization config-commands
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization exec NO_AUTHOR none
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 1 NO_AUTHOR none
aaa authorization commands 15 default group tacacs+ if-authenticated
what step we should follow for this..?
Re: TACACS Problem .....
aaa authentication login default local group tacacs+ LOCAL
Use this one.
this command firstly authenticate the TACACS server after it authenticate local database. if tacacs server not avialable , then it go for local database. in this case we want both tacacs and local server both should be authenticate parallely.
for local user we are not defining any username in tacacs server. we want local user should be login in to the router without authenticate into the TACACS server.
112
