Webcast-Catalyst9k
TDM cross-connect for 1721
Hi all
I have a router 1721 with:
IOS VERSION 12.3(1a)
32K bytes of non volatile configuration memory
32768K bytes of processor board system flash (read/write)
and two cards VWIC-1MFT-G703
(not second generation cards VWIC2-1MFT G703)
In the configuration for E1 drop and insert, i have not the command tdm-group in (config-controller)#
but this is necessary for the command connect!
Any Help for this please?
Tks
1 ACCEPTED SOLUTION
Silver
Re: TDM cross-connect for 1721
Silver
The channel-group 0 command is configured in such a way that the service provider can send Frame Relay link management information (LMI) on the T1 or E1 controller for Frame Relay data services.Refer URL
http://www.cisco.com/en/US/products/hw/routers/ps221/prod_configuration_guide09186a00800a4063.html#wp93759
Silver
thank you very much for your help on this problem. I believe this is the correct answer
TKS
170
