tdp/ldp router id
rabeder
hi,
my problem:
i have a mpls pe router which has a session to an other pe-router.
i want to control the ldp/tdp router-id, so i configured the following:
tag-switching tdp router-id Loopback65052
interface Loopback65052
description mplsrbgope03: OSPF-ID,BGP-ID for AS65052 (Lo65052)
ip address 172.16.24.20 255.255.255.255
but the router has ldp sessions with an other adress (172.16.24.86):
Peer LDP Ident: 172.16.24.62:0; Local LDP Ident 172.16.24.86:0
TCP connection: 172.16.24.62.646 - 172.16.24.86.13269
State: Oper; Msgs sent/rcvd: 46630/46457; Downstream
Up time: 4w0d
LDP discovery sources:
FastEthernet0/0.190, Src IP addr: 172.16.24.93
Addresses bound to peer LDP Ident:
172.16.24.2 172.16.24.62 172.16.26.2 172.16.27.201
172.16.27.205 172.16.27.209 172.16.27.213 172.16.27.217
172.16.27.221 172.16.27.225 172.16.27.229 172.16.27.233
172.16.27.249 172.16.27.237 172.16.27.241 172.16.27.245
172.16.27.253 10.22.255.1 10.22.31.33 10.20.255.133
10.22.255.61 10.22.255.65 10.22.255.73 10.22.63.5
10.22.63.13 10.22.63.25 10.22.31.1 10.22.31.21
10.22.255.9 10.22.63.1 10.20.255.9 10.22.255.29
172.16.25.65 172.16.25.17 172.20.6.5 172.20.6.49
172.20.6.61 172.20.6.69 172.20.6.77 10.18.56.6
10.18.56.8 172.16.24.83 172.16.24.93 172.16.25.157
172.16.25.37 172.16.25.6 10.20.255.1 172.16.25.73
172.20.6.85 172.16.25.9 172.16.25.153 172.16.25.69
172.16.25.81 172.16.25.33 172.20.6.173
Peer LDP Ident: 172.16.24.4:0; Local LDP Ident 172.16.24.86:0
TCP connection: 172.16.24.4.646 - 172.16.24.86.28023
State: Oper; Msgs sent/rcvd: 46717/47314; Downstream
Up time: 4w0d
FastEthernet0/0.190, Src IP addr: 172.16.24.78
172.16.24.4 172.16.24.78
Peer LDP Ident: 172.16.24.61:0; Local LDP Ident 172.16.24.86:0
TCP connection: 172.16.24.61.646 - 172.16.24.86.34584
State: Oper; Msgs sent/rcvd: 46596/46414; Downstream
Up time: 4w0d
FastEthernet0/0.190, Src IP addr: 172.16.24.92
172.16.24.1 172.16.24.61 172.16.25.57 172.16.27.101
172.16.27.105 172.16.27.109 172.16.27.113 172.16.27.117
172.16.27.121 172.16.27.125 172.16.27.129 172.16.27.133
172.16.25.5 172.16.25.61 172.16.25.49 172.16.25.45
172.16.25.41 172.20.6.1 172.20.6.53 172.20.6.57
172.20.6.65 172.20.6.73 172.20.6.81 10.18.56.5
10.18.56.7 172.16.27.137 172.16.25.173 172.16.25.21
172.16.25.109 172.16.27.141 172.16.27.145 172.16.25.53
172.16.25.29 172.16.25.169 172.16.24.92 172.16.32.1
172.16.24.94 172.16.25.181 172.20.6.169 172.16.27.149
1.1.1.1
does anybody has an idea?
i know i use ldp and not tdp on the interface - but i thought that the command "tag-switching tdp router-id Loopback65052" also has an affect to ldp session - right ?
pkhatri
Level 11
Level 11
Did you enter the command after the LDP session was up ? I don't think the command takes effect immediately.
Hope that helps - pls rate the post if it does.
Paresh
hi,
thx
yes, i had already the same idea - i am not sure what happened first.
so at friday night i make a "reload" to the router - then i´ll see
to hritter:
no, i dont like to use the "force" keyword
Harold Ritter
Try configuring the "force" keyword at the end of the command.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
