TE Tunnel isn't honoring rsvp constraint
All,
I'm noticing that if an existing tunnel is up and the reserved bandwidth changes, that doesn't necessarily force the TE to take another path.
For example:
Router A TE Tunnel: BW require 1024
Router B: ip rsvp bandwidth 1024
Router C: ip rsvp bandwidth 1024
Router D: ip rsvp bandwidth 1024
Router E: ip rsvp bandwidth 1024
               C
A   --  B  ----  D  --   E
The head end calculation would be A -> B -> D --> E
I would want it to change to A -> B -> C -> D -> E.
If I change, while the tunnel is up, the incoming interface on D to 'ip rsvp bandwidth 512', the tunnel doesn't change unless I shut the tunnel down and then bring it back up. Is this not supposed to be dynamic when autoroute is enabled and path option is set to dynamic?
John
HTH, John *** Please rate all useful posts ***
1 REPLY
More info:
This is one of the routers in the path of the TE tunnel:
interface FastEthernet0/1
ip address 10.37.37.3 255.255.255.0
duplex auto
speed auto
mpls ip
mpls traffic-eng tunnels
ip rsvp bandwidth 50
end
This is the head end and path calculation:
  Status:
    Admin: up         Oper: up     Path: valid       Signalling: connected
    path option 1, type dynamic (Basis for Setup, path weight 20)
  Config Parameters:
   Bandwidth: 128      kbps (Global)  Priority: 7  7   Affinity: 0x0/0xFFFF
    Metric Type: TE (default)
    AutoRoute:  enabled   LockDown: disabled  Loadshare: 128      bw-based
    auto-bw: disabled
RSVP Signalling Info:
       Src 10.10.10.10, Dst 3.3.3.3, Tun_Id 1, Tun_Instance 85
    RSVP Path Info:
      My Address: 10.107.107.10
      Explicit Route: 10.107.107.7 10.37.37.7 10.37.37.3 3.3.3.3
      Record Route:  NONE
I don't understand how it's choosing the path if it doesn't meet the bandwidth requirements.
144
