Technical Recommendation Required
Hello All,
I would like to give-up the Interview in next few days / months for a technical change over.
Can any-one advice me what all "Preparation Steps" required to make Successfull. Today i am working in a BGP with MPLS environment includes OSPF also.
What all the Major domains / sub-domains i need to concentrate on like:
1.WAN, Routing and Switching
2.LAN, Switching and Routing
3.Getting Started with LANs
What all the Mandatory Topics on which i should be strong enough. Pls Guide me on the request.
Best Regards,
Guru Prasad R
1 REPLY
Silver
Re: Technical Recommendation Required
If you are showing MPLS, BGP and OSPF..
Here are few questions:
1) What is MPLS? Why we have MPLS?
2) VRF?
3) CEF?
4) BGP over MPLS?
5) OSPF ares?
6) Redistribution between OSPF and BGP?
7) Troubleshooting steps MPLS, BGP and OSPF?
8) BGP TCP port NO?
9) What is Multihope?
10) How BGP creates Default route?
11) How can BGP advrtise routes?
Apart from this, from cisco.com search FAQ for MPLZ BGP and OSPF.
You will be fine.
Dharmesh Purohit
94
