Telnet into specific VTY lne
Kevin Dorrell
Level 10
Level 10
I'm having a problem telnetting to a specific VTY line. I thought they were available on ports 3001 onwards, but no joy. I cannot find it in the documentation. This is what is happening:
<code>
R3#telnet 172.16.105.1
Trying 172.16.105.1 ... Open
R5#show run | sec line
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
line vty 0 4
exec-timeout 0 0
privilege level 15
no login
R5#exit
[Connection to 172.16.105.1 closed by foreign host]
R3#telnet 172.16.105.1 3001
Trying 172.16.105.1, 3001 ...
% Connection refused by remote host
R3#
</code>
Where am I going wrong?
Kevin Dorrell
Luxembourg
mohammedmahmoud
Level 11
Level 11
Hi Kevin,
You need to use the rotary command under the VTY line(s), by default all the VTY lines are used sequentially via port 23 (the first free one is used), you can define a rotary group under specific VTY line(s) and use the defined number + 3000 to telnet to this specific line.
BR,
Mohammed Mahmoud.
5 Replies 5
shivlu jain
Level 5
Level 5
kevin
As i know that works with the access server.
For telnet only 23 port works.
regards
shivlu
mohammedmahmoud
Level 11
Level 11
Hi Kevin,
BR,
Mohammed Mahmoud.
Thank you Mohammed, it was exactly that.
Kevin Dorrell
Luxembourg
Kevin,
You are very welcomed, and thank you very much for the rating.
BR,
Mohammed Mahmoud.
lamav
Level 8
Level 8
Interesting
