telnet to secondary IP
If I use private ip and public ip as secondary
router(config)#ip dhcp excluded-address 10.10.10.1 10.10.10.10
router(config)#ip dhcp pool LAN
                    network 10.10.10.0 255.255.255.0
                    default-router 10.10.10.1
                    dns-server 8.8.8.8 8.8.4.4
router(config)#interface Vlan1
                    ip address 5.5.5.5 255.255.255.240 secondary
                    ip address 10.10.10.1 255.255.255.0
                    ip nat inside
                    ip virtual-reassembly in
-any problem gonna be happen in my lan?
-can I telnet to this public ip from outside lan?
-can i use this public ip in vpn site to site vpn ?
thanks
Mahmoud
No your LAN will work just fine
If you decide to route the public IP to the rest of the network and its reachable from other parts of the network you can telnet this IP too.
Yes you can
Umesh
Hello
Why would you want to do this, when you can just nat on that public ip to a lan ip thus hiding you lan from the outside.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Please don't forget to rate any posts that have been helpful. Thanks.
Re: telnet to secondary IP
pdriver wrote:
Hello
res
Paul
Thanks.
thanks pdriver
Iam using 887va router thay act as adsl modem , i have one static public ip but i cant use it under my dialer interface while doing that the internet connection goes down so i need to use this public ip under any interface .i tried loopback interface but doesnt work
Yes you can
Umesh
Thank you  Umesh Shetty for your replay i appreciate that
but can you clearly explain that
tahnks
Mahmoud
Personally, I wouldn't do this. Considering that your vlan supports your switchports, I'd set aside one of those ports as a routed port and put your public address on the routed port and your private on the vlan.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
HTH,
John
Iam using 887va that doesnt support layer 3 ports only svi
390
