TenGigE Interface Sometime fault
I am facing a problem where my TenGigE interface is sometime down.
Diagram:
ASR1K <----> ASR9K
Log on ASR1K :
.Jan 14 07:56:31 GMT+7: %IOSXE_SPA-6-UPDOWN: Interface TenGigabitEthernet0/2/0, link down due to remote fault
On ASR9K, i don't find any log.
By Shut/Commit and No Shut/Commit on ASR9K, the link resumed to normal.
Any idea?
PS: the fiber path cord is around 5m.
CT
Hall of Fame Super Gold
Post the output to the command "sh interface Ten 0/2/0".
PE#sh int ten0/2/0
TenGigabitEthernet0/2/0 is up, line protocol is up
  Hardware is SPA-1X10GE-L-V2, address is 30f7.0d42.2c20 (bia 30f7.0d42.2c20)
  Description: CONNECT ME01-POP1 (T1/30) - TRUNK
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 255/255, rxload 1/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive not supported
  Full Duplex, 10000Mbps, link type is force-up, media type is 10GBase-LR
  output flow-control is on, input flow-control is on
  Last input 00:00:00, output 00:00:05, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 18443
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 29572000 bits/sec, 5833 packets/sec
  5 minute output rate 30406000 bits/sec, 4014 packets/sec
     8553385575 packets input, 5321708311292 bytes, 0 no buffer
     Received 241799997 broadcasts (0 IP multicasts)
     0 watchdog, 996344186 multicast, 0 pause input
     6257933590 packets output, 5661214436454 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Re: TenGigE Interface Sometime fault
Uhhhhh ... WHAT?????
Can you post the "sh interface" from the remote end?
Here is the status on ASR9K:
RP/0/RSP0/CPU0:9K-01-SCT#sh int ten0/0/2/2
Tue Jan 14 11:11:51.864 GMTKH
TenGigE0/0/2/2 is up, line protocol is up
  Interface state transitions: 9
  Hardware is TenGigE, address is 10f3.110c.98de (bia 10f3.110c.98de)
  Layer 1 Transport Mode is LAN
  Description: CONNECT PE
  Layer 2 Transport Mode
  MTU 1514 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
     reliability 255/255, txload 0/255, rxload 0/255
  Encapsulation ARPA,
  Full-duplex, 10000Mb/s, link type is force-up
  output flow control is off, input flow control is off
  loopback not set,
  Last input 00:00:00, output 00:00:00
  5 minute input rate 26035000 bits/sec, 3524 packets/sec
  5 minute output rate 22788000 bits/sec, 5196 packets/sec
     6267071861 packets input, 5670584827328 bytes, 98098 total input drops
     0 drops for unrecognized upper-level protocol
     Received 736499 broadcast packets, 20857 multicast packets
              0 runts, 0 giants, 0 throttles, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     8566988780 packets output, 5330087075217 bytes, 735 total output drops
     Output 242283785 broadcast packets, 996960399 multicast packets
     0 output errors, 0 underruns, 0 applique, 0 resets
     9 carrier transitions
1. Can you confirm what is the length of the fibre optic patch cable?
2.  On the switch, can you post the output to the command "sh interface Ten 0/2/0 transceiver prop"?
1. Confirm the cable length is around 5m (or less then 10m)
2. Below is the output:
ME4900#sh int te1/30 transceiver detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Te1/30      34.7                74.0        70.0         0.0       -4.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Te1/30     0.00                   N/A         N/A         N/A        N/A
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Te1/30      -2.0                 4.4         0.4        -8.2      -12.2
           Receive Power      Threshold   Threshold  Threshold  Threshold
Te1/30     -11.7                 4.4         0.4       -14.4      -18.4
Ok, then finally, can you post the output to the command "sh inventory".  I think I know where the problem is.
If what you are saying is correct, that the fibre optic patch cable is only 5 to 10 metres and the fibre optic used is LR (or LONG REACH), then what your Cisco appliance is behaving (ports go down) is normal.
This is because you are using LR fibre optic modules to shoot at a very short distance.  At 5 to 10 metres you should be using 10GBase-SR
OK, thanks.
I will make it longer and also put attenuators.
Thanks so much for the input.
I am not sure if attenuators are enough.  You need to replace the fibre optic modules (and cable) if the distance is too short.
Some people say it maybe a bug. Is it possible?
LOL!  No it is not a bug.
Someone is using LR fibre modules to shoot traffic down a 5 METRE DISTANCE.  That's not a bug.  That's @#$%^&*!!! stupidity.
* Minimum cabling distance
* Minimum cabling distance for -SR, -LRM, -LR, -ER modules is 2m, according to the IEEE 802.3ae.
There is nothing stupid about
There is nothing stupid about this.
10GBase-LR should work fine over a short distance - attenuators may be needed on the recieve side to protect the optics but that's it.
Suggesting that everyone run multi-mode unless they need long range might be a little short sighted.  Many shop's and telco's standardize on single mode so they do not need to carry two types of cable, optics etc.  The cost difference is relatively minor these days.
Your response is not very helpful to the user.
Did the OP mentioned that attenuators were ever used?  No he did not.
Telcos "may" use LR in short distances (they can stock attenuators all over their network) but they are telcos.  They "may" know what they are doing with their optical modules.
This OP doesn't work for a Telco.  Trying to encourage people not to follow good practices and/or standard because "hey, if the telcos can do it, why can't I" ain't really helpful either.
To be honest, I disagree.
Some people here don't have deep pockets.  A lot of people (and their employers) find it difficult to justify going down the Cisco road as opposed to HP or Juniper.
It's not just technically stup1d but also financially.
Do you know how much a 10 Gbps LR module costs?
Typically, a 10 Gbps LR modules is DOUBLE the cost of a 10 Gbps SR module.
VIP Super Bronze
Also, one thing I suggest you do is to clean the fiber tips with alcohol.  You may have dirty fiber strands on one side.
It's a bug as shown here :
It's a bug as shown here : https://tools.cisco.com/bugsearch/bug/CSCun88935/?referring_site=bugquickviewclick
4150
