terminal monitor default on
I want to enable terminal monitor on always when connecting via telnet. How can i do that?
Thank you
Re: terminal monitor default on
I dont think it is possible
Typing the command everytime is not difficult either :-)
Silver
you can try one thing that bind the term mon on with the exec and try to add with the telnet. Means when the telnet session will be opened it will run the command automatically.
regards
shivlu
Try adding monitor under line vty.
712
