Community Member
Terminating PBX E1 line on NMCE1T1-PRI module port
Hi everybody. I have small doubt. Is it possible to terminate PBX on Channelized E1T1-PRI module port and will the module support Voice ?
Thanks in Advance.
Silver
Re: Terminating PBX E1 line on NMCE1T1-PRI module port
Yes you can. What is the correct type of the module, because if you want that the calls to be sent through voip then you have to have DSP's on it.
Hope it helps,
Krisztian
Community Member
Hi Krisztian,
I have NM-2CE1T1-PRI module.
can I coonect PBX to this module E1 port ?
How would be the configuration ?
I am using 3845 router and vae DSPs on it.
awaiting for ur reply
Thanks in Advance
AlluReddy
Silver
I think the NM-2CE1T1 can be used only for WAN connection or for modem termination (using appropriate DSP). If you want to use voice then you need to have HDV module.
Anyway the PBX can be connected to the PRI port.
Community Member
Thanks for ur Reply.
So this module does not support voice. And I want to terminate PBX on E1 for voice only.
Thanks for ur Information.
185
