Community Member
Three ISP and gateway temporarily unreachable
I have a 2801 with HWIC-4ESW and three isp connection with tracking, sla etc. (read config)
ISP1 and ISP2 links works fine, but ISP3 every 1-2 min cannot ping gateway and track state go "DOWN" state. After that i try ping gateway from vlan3:
#ping ISP3_GW
and track goes "UP", and this only possible what track go UP(when ping ISP3_IP from WAN, ISP3_IP not reply).
I try delete all additional options(track,nat,route-map..) from config and configure ISP3 on other interface(fa0/0), but have same result..
Only this ISP3 link go through converter to fiber, but with workstation PC this ISP3 link works normally.
Silver
Re: Three ISP and gateway temporarily unreachable
have you checked ur fiber link fine?
This workstation in not going through fiber?
Community Member
yes, i tested this link with workstation and PIX, it worked normally, all ping reply from gateway recieved..
it's miracle..
85
