04-03-2009 09:41 PM - edited 03-04-2019 04:14 AM
three remote sites will be deployed. Attched the network design diagram. I have some questions and seek for expert advices
1. there is VLAN config in HQ. Does it config the VLAN in remote site?
2. any "trunk mode" is better? ISL, 802.1q, ...
3. if I config the VTP to manage the vlan between the remote sites and HQ, it can simply the vlan management. any approach is better than using VTP?
4. any sample config in HQ and remote site are welcome (URL link is welcome as well)
5. if I enable the "L2" circuit instead of MetroEthernet, is it a better solution? does it have broadcast storm issue? how to address it?
rdgs
Solved! Go to Solution.
04-04-2009 09:52 AM
Anita:
The carrier will most likely terminate the circuit at both ends using a device that has an RJ-45 interface. You will have to run an ethernet cable from your switch port to the terminating device's RJ-45 receptacle, and then configure your switchport port as a trunk with spanning tree configurations, as you normally would if the other end were local.
Victor
04-04-2009 06:25 AM
1.) Anita, if you are extending the vlan from the headquarters over the Metro-E connection to your remote site, then, yes, absolutely; you must configure the vlan on the headquarters and remote sites. You also have to allow it on the trunk.
2.) I think all carriers of Metro-E use Q-in-Q tunneling, so you would have no choice but to use dot1q.
3.) My suggestion regarding VTP is dont use it. You dont need it. It is more of a headache than its worth. Set the switches to VTP Transparent mode, which effectively shuts it off.
4.) Try Cisco's website.
5.) Im not sure I understand what you are asking. A metro-E connection is a layer 2 circuit. Its a wide area ethernet connection.
04-04-2009 09:17 AM
regarding Q5, the provider can offer "extend ethernet" circuit. it means that the "A" end is "RJ45" interface which connect to HQ ethernet switch. The "B" end is "RJ45" interface which connect to remote site ethernet switch. There is no any setting on both sides (HQ, remote site).
But it may have broadcast storm issue.
rdgs
04-04-2009 09:52 AM
Anita:
Victor
