Community Member
TI/E1 and ISDN
From the Ciscopress CCIE book:
BRI = 2B + 1D
2x64 + 16 = 144 Kbit/sec
I'm cool with this
PRI T1= 23B + 1D
23x64 + 64 = 1536 Kbit/sec
If it's true that the D channel is 64, from my calculation the the total bandwidth required is: 1536 which is more that 1522 (standard T1)
confused :-?
PRI e1= 30B + 1D
30x64 + 64 = 1985 Kbit/sec
Is in this case is the E1 underutilized as the bandwidth available is 2048?
And if so is there any tech reason for this?
Thanks to read!
Re: TI/E1 and ISDN
All the numbers indicated 2B+1D, 23B+1D and 30B + 1D are all properl. And for B and D channels in PRI (T1 and E1) is 64 kbps.
So when you sum it up, the bandwidth is only 1536 for T1. Where is the other 8 kbps (True T1 is 1544kbps and not 1522kbps). 1536 kbps is the payload bandwidth. 8kbps is used for framing and synchronization.
A base T1 frame has 193 bits, 24 time slots. The first bit of each frame forms the synchronization channel which creates the 8 kbps channel.
A E1 frame has 256 bits, 32 time slots and one 64 bit channel is dedicated for frame synchronization, alarms etc just like the 8 kbps channel for T1. Another 64 kbps channel is used for signalling (the D channel of E1) and the rest 30 channels are used for payload (each 64kbps).
Sankar.
Community Member
Re: TI/E1 and ISDN
I think now it's quite clear, but I miss to understand the function of the 8Kbit in T1 and 64Kbit in E1.
I thought the D channel was meant for this function, but according with what you say there are 2 things to take into account:
1) The low lever framing synchronization/alarms fro T1 and E1 (8 Kbps and 64 Kbps)
2) the D channel used at higher lever by ISDN for signaling
290
