Webcast-Catalyst9k
TinyRom error 800
When ever I save a config on this 800 series router I am getting this message.
WARNING: no valid "boot system" command. TinyROM will
pick an IOS image to boot.
If I view the flash I get;
0 ---- 49096 Nov 8 2000 03:37:53 +00:00 TinyROM-1.4(1)
1 -r-x 4836308 Jun 9 2004 02:32:27 +00:00 c800-y6-mw.123-5d.bin
Is this an error or something I should be concerned about?
1 ACCEPTED SOLUTION
Purple
Re: TinyRom error 800
I believe what the message is saying is that the default IOS rules will be used for determining which image is used to boot up the router.. Since you only have one image, it's not an issue but you can probably make the message go away by configuring the following:
boot system flash:c800-y6-mw.123-5d.bin
Hope that helps - pls rate the post if it does.
Paresh
Purple
Paresh
thanks Paresh, that indeed has got rid of the message,
Rob
123
