To benefit of Multilink Frame Relay (FRF.16.1)
We have 4 E1 links with for 32 links 256 bits encapsulation frame relay. The links are point to point , each link have their DLCI and on router tha we have 4 E1 are 32 DLCI
To benefit of Multilink Frame Relay (FRF.16.1) what we can do?
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: To benefit of Multilink Frame Relay (FRF.16.1)
Please see the configuration examples in the manual:
http://cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087cbf.html
As an appreciation to those providing answers, remember to rate useful posts using the scrollbox below!
The first and foremost benefit is that you can have, in the hub site, enough bandwidth to support the sum of access speed, and CIR, for all the branches, without worrying about splitting the branches in groups to map into a single link.
Also to consider, redundancy due to the multiple links, and efficiency compared to an ATM/FR solution, due to the much smaller overhead.
thank you !
can you give me an example of configuration that is needed
130
