Token ring support on ISR G2
My customer wants to replace some Cisco 2912 by new routers, but I can't find a way to add Token ring Network Module on  2951 or 3925 routers with the Cisco configuration tool.
Does somebody know if token ring is still supported on ISR G2 routers?
J-F
Gold
Here is what it does support:  off hand, I would say its time to convert to ethernet.
Table 4. Cisco 3900 with Cisco IOS  Software Feature and Protocol High-Level Support
Protocols
• IPv4, IPv6, static routes, Open Shortest Path First  (OSPF), Enhanced IGRP (EIGRP), Border Gateway Protocol (BGP), BGP Router  Reflector, Intermediate System-to-Intermediate System (IS-IS), Multicast  Internet Group Management Protocol (IGMPv3), Protocol Independent Multicast  sparse mode (PIM SM), PIM Source Specific Multicast (SSM), Distance Vector  Multicast Routing Protocol (DVMRP), IPv4-to-IPv6 Multicast, MPLS, Layer 2 and  Layer 3 VPN, IPSec, Layer 2 Tunneling Protocol Version 3 (L2TPv3), Bidirectional  Forwarding Detection (BFD), IEEE802.1ag, and IEEE802.3ah.
Encapsulations
• Generic routing encapsulation (GRE),  Ethernet, 802.1q VLAN, Point-to-Point Protocol (PPP), Multilink Point-to-Point  Protocol (MLPPP), Frame Relay, Multilink Frame Relay (MLFR) (FR.15 and FR.16),  High-Level Data Link Control (HDLC), Serial (RS-232, RS-449, X.21, V.35, and  EIA-530), PPP over Ethernet (PPPoE), and ATM.
Hall of Fame Super Silver
J-F
As far as I know there is no support for token ring in ISR G2.
Rick
Gold
last thing i could find was a 3640...and that was in the EOS announcements.
It seems that it was still supported on ISR:
Gold
It 'appears" that item "might" be referring to some form of encapsulation.
Here is the link to the supported interfaces and modules:
http://www.cisco.com/en/US/products/ps10537/products_relevant_interfaces_and_modules.html
no T/R mods...
gotta go....i hear beaconing somewhere
737
