Trace route, problem
feroz syed
Level 3
Level 3
This is eigrp topology, when i do a traceroute from  Branch 1 to Branch 3 router it show like this
Branch1#traceroute 10.1.3.1
Tracing the route to 10.1.3.1
  1 193.10.26.1 64 msec
    193.10.25.1 40 msec
    193.10.26.1 20 msec
  2 193.10.24.2 40 msec
    193.10.24.6 24 msec
    193.10.24.2 8 msec
If you see the output what is the meaning of 1 and 2 ?? and why it displaying two times same ip.  waiting for your replys......
cadet alain
packets originated by or destined to the router are process switched and  load-sharing for process switched packets is per packet.So  first udp packet is sent to 26.1 then next to 25.1 and next to 26.1 again.
It means you have 2 paths to go to destination on which you are load-sharing with a share ratio of 1:1
Alain
cadet alain
Alain
Thanks for your reply alain, but why it not end with 10.1.3.1 ?
It should and your traceroute output is not complete here.
Alain
No i paste it completly, i ll paste it here again
Branch1#ping 10.1.3.1
Sending 5, 100-byte ICMP Echos to 10.1.3.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/30/64 ms
  1 193.10.26.1 80 msec
    193.10.25.1 40 msec
    193.10.26.1 20 msec
  2 193.10.24.2 8 msec
    193.10.24.6 32 msec
    193.10.24.2 8 msec
Branch1#
