12-26-2013 01:52 PM - edited 03-04-2019 09:56 PM
I am trying to get a better understanding of how to read this traceroute because there is nothing blocking icmp on the test network I have setup. I am also not sure why there are multiple entries for hop 4. Shouldn't there only be a single hop?
R1#traceroute 6.6.6.6
Tracing the route to 6.6.6.6
1 * * *
2 * * *
3 * * *
4 10.5.6.6 240 msec
10.6.7.6 232 msec
10.5.6.6 212 msec
Thank you,
Alex
Solved! Go to Solution.
12-27-2013 02:48 AM
Cisco IOS uses UDP for traceroute not ICMP and it sends 3 probes with same TTL to different udp destination ports so that's why you see the 2 different IP adresses because you have 2 paths to destination.
Alain
12-27-2013 02:48 AM
Alain
