08-06-2010 08:57 PM - edited 03-04-2019 09:20 AM
Just wish to ask the below.
1. If i do a traceroute from a workstation directly connected to a router, to a destination that goes through the tunnel interface L0 of that same router, will the tunnel interface IP show on the traceroute results?
2. If the destination workstation is directly connected to another router where the tunnel terminates, will the tunnel endpoint IP appear in the traceroute results?
Thanks.
Solved! Go to Solution.
08-07-2010 08:57 AM
Hi Giuseppe,
it's even a little more complicated.
The tunnel endpoint IP address should be visible twice in the traceroute output.
See https://supportforums.cisco.com/message/3143453#3143453
for details.
BR,
Milan
08-07-2010 04:17 AM
Hello Mark,
if we think of a GRE point to point tunnel it works like an envelope that inside carries the user packets.
traceroute works by sending UDP packets with destination = traceroute destination using an high UDP port.
First series of packets are sent out with TTL=1 PC default gateway answers with an ICMP unreachable (TTL expired) as the packet cannot be delivered to intended destination.
Second series of traceroute probe packets are sent out with TTL=2, sender PC default gateway decrease TTL to 1 recomputes IPv4 header and sends the packet encapsulated in a GRE header to the tunnel endpoint router.
The tunnel endpoint router decapsulates the packet detects TTL=1 and so it knows that it cannot deliver the packet to the intended destination.
The tunnel endpoiint router prepares an ICMP unreachable (TTL expired) packet to be sent back to traceroute probe sender and consulting its own IP routing table discovers that it has to send the packet over a GRE tunnel this allows to choice the source address of the ICMP unreachable message that should be the one in direction to original source.
So the PC that has sent the traceroute probes should see:
its own default gateway
IP address of the tunnel endpoint (remote router) on the GRE tunnel towards sender PC default gateway
the IP address of destination PC
the destination PC will send back an ICMP packet with a different code (protocol unreachable) when probe TTL=3
if no ip unreachable is configured on any interface used as a source for sending ICMP unreachables on the path you will see a * for that next-hop meaning no answer has been received
Hope to help
Giuseppe
08-07-2010 08:57 AM
Hi Giuseppe,
for details.
BR,
Milan
08-07-2010 11:06 AM
Hello Milan,
thanks for your correction
that thread is interesting as it shows exactly what the original poster of this thread was asking and provides explanation for the observed behaviour
rated as it deserves
Best Regards
Giuseppe
