Track, BGP and HSRP
Hi guys,
Needing some help with something that is just a little beyond me.
Have a customer, who will have 2 BGP connections, one with us, one with another ISP.
Customer has 2x 1811 routers to do this, one for each external connection.
The idea is that if provider 1 fails, the secondary will preempt via HSRP and become the local gateway.
Problem comes in that they wish to do tracking on the primary ISP so that in the event of a in direct failover the secondary will take over in a short time.
I have setup tracking on the primary router, this will eventually track a loopback one of ISP1's border routers.
It should also check that they are getting a default route from ISP1 (customer is only accepting default routes).
Now I with a little bit of searching I figure that I need to have a route map in the primary, which will remove the advertised subnet on the event of a tracking failure.
However I’m not exactly sure of what I should be using to get this to happen.
Could someone tell me what I should be looking at to be doing this.
Below is my testing configurations.
Regards Richard
Router A
neighbor 10.0.0.1 remote-as 1
neighbor 10.0.0.1 description ISP1
neighbor 10.0.0.1 version 4
neighbor 10.0.0.1 timers 30 90
neighbor 10.0.0.1 remove-private-as
neighbor 10.0.0.1 prefix-list defaultroute in
neighbor 10.0.0.1 route-map AS1-in in
ip sla 1
icmp-echo 10.10.10.10
request-data-size 1400
timeout 1000
frequency 30
ip sla schedule 5 life forever start-time now
track 1 rtr 1 state
track 2 ip route 0.0.0.0 0.0.0.0 state
interface Vlan1
ip address 172.16.0.2 255.255.255.0
standby 1 ip 172.16.0.1
standby 1 priority 105
standby 1 preempt delay minimum 60
standby 1 track FastEthernet0
standby 1 track 1 decrement 20
standby 1 track 2 decrement 20
route-map AS64900-in permit 50
match ip address originated
route-map AS64900-in permit 60
local pref 110
(these added incase of possible future changes)
router B
Configured with ISP 2 BGP session, route-maps to prepend AS# and HSRP preempt. I figured this probably isnt needed but if required i'll post.
**edit to fix formatting
1 ACCEPTED SOLUTION
Purple
Re: Track, BGP and HSRP
Hi Richard,
I'm pretty sure there is no way to bring an actual BGP session down, based on the result of a tracked object. But why would you want to bring the session down anyway ? If the aim is not to advertise the local networks over the BGP session when a tracked object goes down you can do something like the following:
router bgp 64512
network 10.1.1.0 mask 255.255.255.0
ip route 10.1.1.0 255.255.255.0 null0 track 2
That way, you don't have to kill the session but the injected routes will no longer be injected when the tracked onject is down.
Pls do rate the posts if you find them helpful..
Paresh
Purple
I'm not totally clear on what you are trying to do - what is this 'advertised subnet' that you wish to remove on a tracking failure ?
Paresh
Sorry,
After work rambling :)
Basically if routerA cannot get a response from its tracking host, shut down the BGP session.
Richard
Purple
Hi Richard,
router bgp 64512
Paresh
Paresh,
I'll try this in the morning.
Removing the route is just as acceptable, I should have said this :)
Can you explain why adding a null route will stop the route from being advertised ?
Purple
The null route is not what causes the route to stop being advertised - it's the 'track 2' that causes it. The null0 route simply ensures that we have a static route that we can track using a tracking object.
Pls do rate the posts if you find them helpful...
Paresh
Paresh,
If the subnet is directly connected wont this override the lack of a static route and continue to advertise the subnet ?
R
Purple
Yes, it would.. but in most cases, you would not be advertise small blocks but the whole aggregate that belongs to the customer. If the static route is for that aggregate (and the specifics are not advertised, which is the norm), the technique still works...
Pls rate the post if it makes sense :-)
Paresh
Paresh,
All works wonderfully.
Thanks heaps.
3133
