04-23-2012 08:57 AM - edited 03-04-2019 04:07 PM
All,
The only option that I have under the IOS that's installed on a 2900 series router is track. I don't have a version that supports SLA. The interface is connected to a switch that the ISP gave, and all of the tests that I've done refuse to make the circuit go down. If I were to lose the circuit, the interface won't show to be down unless the switch were to go down.
Is there any way with track to see that the provider's circuit went down on a switch? I was going to set up sla to ping the ISP's address, but I can't do that unless I upgrade the OS. These are a pair of routers running hsrp at a remote datacenter. Is sla the only way that I'm going to be able to accomplish this? I have tried track with different options in gns and all of them keep the CE's interface up and doesn't show it down. Watching a route in the table isn't feasible because I wouldn't want it to fail over because another site is having problems. Tracking the route doesn't work for connected routes either because the route itself doesn't leave the table as long as the interface is up.
John
Solved! Go to Solution.
04-23-2012 09:12 AM
John,
You need to upgrade the IOS and go w/ IP SLA to fulfill this task.
Edison
04-23-2012 03:04 PM
04-23-2012 09:12 AM
John,
Edison
04-23-2012 09:14 AM
That's what I was afraid of
Thanks Edison!
04-23-2012 10:34 AM
John,
Can you check if BFD is available for you? That could be an alternative.
04-23-2012 11:37 AM
It's not. We're running IPBase, but I had some questions about the format of the new images. When I search for an image that supports bgp, qos, and sla, I come back with a few images that *looks* like it supports it. A screenshot is below:
If you notice above, the Universal (whatever) all point to the same file. How are these licensed now? I downloaded the Universal (Data) one, but it still doesn't have sla support.
Thanks!
John
04-23-2012 03:04 PM
