track ip or rtr?
Hi there,
Tried to play around with this track command.
track 12 ip route 192.168.0.2 255.255.255.0 reachability
track 13 rtr 3 reachability
Is there any difference when using  ip verses rtr
R1#sh track
Track 12
  IP route 192.168.0.2 255.255.255.0 reachability
  Reachability is Down (no route)
    1 change, last change 01:58:04
  First-hop interface is unknown
  Tracked by:
    STATIC-IP-ROUTING 0
Track 13
  Response Time Reporter 3 reachability
  Reachability is Up
    1 change, last change 02:31:27
  Latest operation return code: Unknown
  Tracked by:
    STATIC-IP-ROUTING 0
Everyone's tags (1)
1 ACCEPTED SOLUTION
track ip or rtr?
"track .. ip route" is used to track the state of an IP route specifically.
http://www.cisco.com/en/US/docs/ios/12_3/ipaddr/command/reference/ip1_t1g.html#wp1078859
"track rtr" is for checking/tracking the state using a Cisco IOS IP SLAs operation.RTR is actually an old name of IP SLA and you can use it to test/monitor a number of path parameters, such as delay or jitter.
See this giude on more details of RTR and its configuration:
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
track ip or rtr?
Kind Regards,
Ivan
track ip or rtr?
Thanks Ivan!
track ip or rtr?
Welcome!
665
