Webcast-Catalyst9k
track ip route COMMAND
Can some one explain how this will work with change in metric. what does threshold mean here and how to configure threshold.
ROUTER(config)#track 1 ip route 2.2.2.2/32 metric threshold ?
<cr>
I cannot put threshold value here..
Thx,
G
1 REPLY
Bronze
Re: track ip route COMMAND
Hi gaurav,
The default up and down threshold values are 254 and 255, respectively. With these values, IP route threshold tracking gives the same result as IP route reachability tracking.
your command
Gives the default values mentioned above.
To set a metric threshold other than the default value, use the threshold metric command in tracking configuration mode. To disable the metric threshold, use the no form of this command.
threshold metric up number down number
no threshold metric up number down number
example:
track 1 ip route 10.22.0.0/16 metric threshold
threshold metric up 16 down 20
The metric default value is changed to 16 for the up threshold and to 20 for the down threshold.
Hope this helps you
Raj
1445
