track RTR unrecognized
666Maverick
Hello, I have a cisco 2811 with a IOS Version 12.4(15)T.
I want implement this line in my configuration :
track 1 rtr reachability
But the rtr command is unrecognized. With this link, rtr is recognized... I don't understand.. Have you a solution ?
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html#wp1087990
You need Advanced IP Services for rtr since you only have IP Base.
HTH,
__
Edison.
9 Replies 9
Richard Burts
Fabien
I believe that you are missing a parameter in your command. I checked on a router running 12.4(15)T and if I entered:
track 1 rtr 1 reachability
it was accepted just fine. On line help indicates that the parameter that you missed is an entry number.
Rick
Rick
I have tested. It don't recognized rtr.
It don't know what is it.
It have some versions of 12.4(15)T.
I must have a specific parameter for the recognition of this command by the IOS?
I don't understand...
Please take us through your online help.
At the router type:
track ?
then
track 1 ?
and post the output.
HTH,
__
Edison.
Fabien
I tested on a router running 12.4(15)T as you said. When I entered the command as you posted it I got an error. When I entered the command with the additional parameter that I told you about then the command was accepted.
I believe that the suggestion from Edison is an excellent suggestion. Work your way through the command using on line help and post the results. That will give us a clear view of what is happening.
Rick
Rick
Hi.
Thanks for your help.
When I type track ?
I have :
"<1-500>" Tracked object
"resolution" Tracking resolution parameters
"timer" Polling interval timers
When I type track 1 ?
I have :
"interface" Select an interface to track
"ip" IP protocol
"list" Group objects in a list
"stub-object" Stub tracking object
Why haven't I rtr ?
Thank you for your help.
I wonder what feature set you are running, please post the entire show version output.
HTH,
__
Edison.
Hi.
Here it's the show version :
Router>show version
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(15)T, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Mon 25-Jun-07 22:11 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Router uptime is 9 hours, 49 minutes
System returned to ROM by reload at 11:33:53 UTC Tue May 6 2008
System image file is "flash:c2800nm-ipbase-mz.124-15.T.bin"
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FHK0923F02C
2 FastEthernet interfaces
2 ATM interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Fabien
Edison's suggestion was very helpful. Your post of the online help going through the track command does show that your version does not support the rtr feature. Yet a router that I tested running 12.4(15)T did support it. The difference appears to be that the router that I was running on had the Advanced Security feature set wehre you have the IP Base feature set. Apparently it is a feature set difference.
Rick
Rick
HTH,
__
Edison.
