Tracking state remains down -- 1811W
Hi everyone
I am having an issue were the tracking state does not change to up after a simulated fail and the only way to change it to reachability up is by doing a reload.
So any ideas what am i doign wrong?
ip sla 1
icmp-echo 68.87.76.178 source-interface FastEthernet0
timeout 1000
threshold 800
frequency 10
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 69.110.95.110 source-interface FastEthernet1
timeout 1000
threshold 500
frequency 10
ip sla schedule 2 life forever start-time now
Re: Tracking state remains down -- 1811W
Am i posting in the wrong forums?
Hall of Fame Super Bronze
Can we see some verification output such as:
sh ip sla monitor operational-state
sh ip sla monitor statistics
sh track
Before and After the failure.
__
Edison.
Hi edison thx for your reply.
I solved the issue by reducing the
threshold from 40 to 20. What does the threshold do exacly?
I have my isp1 connection to Fastethernet0 and my isp2 connection to Fastethernet1.
I had the isp2 modem off but when i did a relaod on the router and the router stoped working after the reboot till I unpluged the isp2 cable and only then the isp1 connection fastethernet0 started working again.
Any idea why it would do that?
My second question is I have an exchange server with a local ip of 192.168.1.20 how do I configure the router to use isp1 by default but if isp1 fails use isp2?
Thank you very much for your help.
The threshold is an optional entry and it's used for proactive monitor within the SLA. If you decided to place a value to the threshold, there is more configuration that needs to be done. I suggest you read this document
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsthresh.html
I can't tell what the problem may be based on one paragraph. Please post some outputs when the problem occur such as show ip route, show ip int brief, show ip nat trans. Were you trying to reach the internet from behind the router or from the router itself? Etc....
This is very tricky and requires you do to some work not only at the router itself but with your ISP. Your incoming mail is pointing to an external MX record which is hosted by your DNS provider. This MX record needs to be updated to include ISP1 IP address along with ISP2 IP address.
At the router side, this is something I never personally done (static NAT with track).
__
Edison.
This is after a reload with both wans plugged in but dsl modem is offline. I cannot access the internet or ping 70.xx.xx.xx until I shutdown fa1.
isp1=70.xx.xx.xx
isp2=69.xx.xx.xx
Cisco-1811#sh track
Track 10
Response Time Reporter 1 reachability
Reachability is Up
1 change, last change 01:15:19
Delay up 10 secs, down 15 secs
Latest operation return code: OK
Latest RTT (millisecs) 1
Tracked by:
STATIC-IP-ROUTING 0
Track 20
Response Time Reporter 2 reachability
Reachability is Down
2 changes, last change 01:14:35
Latest operation return code: Timeout
Tracked by:
STATIC-IP-ROUTING 0
show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 70.xx.xx.xx to network 0.0.0.0
69.xx.xx.xx/xx is subnetted, 1 subnets
C 69.xx.xx.xx is directly connected, FastEthernet1
70.xx.xx.xx/xx is subnetted, 1 subnets
C 70.xx.xx.xx is directly connected, FastEthernet0
C 192.168.0.0/24 is directly connected, Vlan1
S* 0.0.0.0/0 [1/0] via 70.xx.xx.xx, FastEthernet0
Cisco-1811#sh ip int brief
FastEthernet0 70.xx.xx.xx YES NVRAM up up
FastEthernet1 69.xx.xx.xx YES NVRAM up up
FastEthernet2 unassigned YES unset up up
FastEthernet3 unassigned YES unset up down
FastEthernet4 unassigned YES unset up down
FastEthernet5 unassigned YES unset up down
FastEthernet6 unassigned YES unset up down
FastEthernet7 unassigned YES unset up down
FastEthernet8 unassigned YES unset up down
FastEthernet9 unassigned YES unset up down
Dot11Radio0 unassigned YES NVRAM administratively down down
--More-- Dot11Radio1 unassigned YES NVRAM
From the router itself or from a device sitting behind the router?
Can you ping the next hop 70.x.x.x while Fa1 is up from the router ?
woa well this is interesting.
With Fa1 up everything is fine but when i turn off the modem for fa1, I can ping from the router and i can browse the web just fine the interesting part is i cannot telnet to it anymore with fa1 down and if i ping the 70.xx.xx.xx from an outside computer it fails.
It makes no sense. I would like to see the show ip interface brief and show ip nat trans while that's occuring...
Dot11Radio1 unassigned YES NVRAM administratively down down
Vlan1 192.168.0.1 YES NVRAM up up
Async1 unassigned YES NVRAM down down
NVI0 unassigned NO unset up up
Cisco-1811#show ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 70.xx.xx.xx:512 192.168.0.3:512 209.73.170.243:512 209.73.170.243:512
I don't see any odd behavior here.
1) Both interfaces are up
2) NAT is translating for 70.x.x.x which is preferred.
What's exactly the problem?
Were you able to connect to the internet while you took those outputs?
You should be able to as I see an ICMP translation.
FastEthernet1 69.xx.xx.xx YES NVRAM up up --> the modem is off the hook on this one to simulate failure.
I can browse the web and i can ping anything from inside but if i try to ping the 70.xx.xx.xx from an outside computer it fails... maybe its by design.
thank you for you help.
192
