Tracking
Hi all,
What happens if I install two routes like
ip route 1.1.1.0 255.255.255.0 2.2.2.2 track100
and
ip route 1.1.1.0 255.255.255.0 3.3.3.3 track 120
and if both tracks are in "UP" state ?
Is equal cost load balancing taken into account on Cisco router ?
Also I noticed that when I install two routes like
ip route 1.1.1.0 255.255.255.0 2.2.2.2 (without track)
and
ip route 1.1.1.0 255.255.255.0 2.2.2.2 track 123
which route is installed ? if tracking is up, do both routes get installed ?
Thanks in advance.
Hall of Fame Super Silver
Re: Tracking
Hello Dumlu,
good question
documentation talks of a primary route (tracked) and a secondary route (floating and not tracked)
to be noted that you cannot specify an AD on a static route with track option enabled.
However, if you don't use local policy you probably can use both but it is something to be tested.
see
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html#wp1070516
Hope to help
Giuseppe
Re: Tracking
Hi Giuseppe,
Thanks for the answer but on a Cisco 3750 Ive just been able to add a static route both with an AD and a track ???
KRK-LAN-3750(config)#ip rou
KRK-LAN-3750(config)#ip route 1.1.1.0 ?
A.B.C.D Destination prefix mask
KRK-LAN-3750(config)#ip route 1.1.1.0 255.255.255.0 10.44.1.1 ?
<1-255> Distance metric for this route
name Specify name of the next hop
permanent permanent route
tag Set tag for this route
track Install route depending on tracked item
KRK-LAN-3750(config)#ip route 1.1.1.0 255.255.255.0 10.44.1.1 10 ?
KRK-LAN-3750(config)#ip route 1.1.1.0 255.255.255.0 10.44.1.1 10 trak
KRK-LAN-3750(config)#ip route 1.1.1.0 255.255.255.0 10.44.1.1 10 trac
KRK-LAN-3750(config)#ip route 1.1.1.0 255.255.255.0 10.44.1.1 10 track 123
KRK-LAN-3750(config)#do show ip route static
1.0.0.0/24 is subnetted, 1 subnets
S 1.1.1.0 [10/0] via 10.44.1.1
195.87.29.0/32 is subnetted, 1 subnets
S 195.87.29.222 [1/0] via 10.44.1.1
81.0.0.0/29 is subnetted, 2 subnets
S 81.8.106.144 [1/0] via 81.8.106.154
195.87.78.0/29 is subnetted, 1 subnets
S 195.87.78.80 [1/0] via 10.44.1.1
198.18.1.0/32 is subnetted, 1 subnets
S 198.18.1.65 [1/0] via 10.44.1.1
KRK-LAN-3750(config)#do sh ver
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(44)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 05-Jan-08 00:29 by weiliu
Image text-base: 0x00003000, data-base: 0x01800000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
KRK-LAN-3750 uptime is 30 weeks, 6 days, 13 hours, 31 minutes
System image file is "flash:/c3750-advipservicesk9-mz.122-44.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-24TS (PowerPC405) processor (revision L0) with 118784K/12280K bytes of memory.
Processor board ID CAT1037RHLM
Last reset from power-on
9 Virtual Ethernet interfaces
Re: Tracking
Hello Dumlu,
yes you have been able to set AD to 10 and to add a tracking option
A collegue of mine had tried to configure on a c2811
But I see it is possible on another c2811 we have in production
ip route 1.1.1.0 255.255.255.0 tunnel18 210 track ?
<1-500> tracked object number
or also as
ip route 1.1.1.0 255.255.255.0 tunnel18 track 100 ?
System image file is "flash:c2800nm-adventerprisek9-mz.124-7a.bin"
So my note is wrong or release dependent
Thanks for your feedback this could open to the possibility of a multi-level hierarchy of tracked static routes.
Hope to help
Giuseppe
Re: Tracking
Hi again,
Well Guiseppe I am still just curious if it does load balancing in case both tracks are up :)
275
