Traffic issue is Serial
In one of my project router we when I check the interface of my serial
by command sh int s0 In Input interface I can see traffic but on output interface traffic is showing to be 0 bits.sec and same is happening on the router at other end Out going is showing traffic but incoming is zero but project people are working fine, thought there are complaints of slow connectivity but they are able to work what I am not understanding over here is why interface is shoing no traffic?
any help will be appreciated
VIP Purple
Re: Traffic issue is Serial
which counter are you looking at ? The 5 minute input/output rate ?
GP
Yes, GP
I am looking at that counter
VIP Purple
if traffic is low, that counter actually might average 0. Below is, what I think. a pretty good explanation of how the counter works. What it comes down to is that it averages the incoming/outgoing traffic over a period of five minutes...
In order to get a better picture of the actual traffic, have a look at the ´packets input´ and ´packets output´ counters, these are cumulative.
Average number of bits and packets received/transmitted per second in the last 5 minutes.
The 5-minute input and output rates should be used only as an approximation of traffic per second during a given 5-minute period. These rates are exponentially weighted averages with a time constant of 5 minutes. A period of four time constants must pass before the average will be within two percent of the instantaneous rate of a uniform stream of traffic over that period.
Also, here is a link that explains all the other counters as well:
Understanding the SHOW INTERFACE SERIAL stats
http://www.tek-tips.com/faqs.cfm?fid=1310
HTH,
GP
I feel since your remote location is uploading some bulk data to your location you are seeing the increase in OUT counters there at the remote end and the IN counters at your end.
for more accurate info i would suggest to tweak the load-interval to 30 seconds.
Also just generate a continous ping and check if there are any increments in the OUT counters at your end router..
regds..
105
