Traffic-Limit
Alcides Miguel
Hello folks,
I'm looking for help on traffic limit (shapping) 'cause I've a Hub-and-Spoke topology where the remote site are all using 128K and I would like to avoid congestion making the egress and ingress traffic not going over the link capacity.
best regard,
Alcides
18 Replies 18
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
What kind of WAN technology?
Hi Joseph,
I don't konw if I'm wright but I'm using dedicated point-to-point links with GRE interfaces.
thanks,
Alcides,
for GRE tunnels you have a couple of options to shape ur traffic, but it all depends on what exactly u have in mind. traffic will be limitted to 128K at last, by congestion management, do you mean you want to drop the excess traffic at the begining or you want prioritize some flows so they wouldnt get stuck in congestion?
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
Hi Soroushm,
thanks you all,
what I wan't is to prioritize some traffic but also prevent traffic not exced the link capacity
best regards,
Alcides
Disclaimer
Posting
How many spokes (each 128K?) and what's the hub's physical bandwidth?  What's the physical interface technology (both sides)?
Hi Joseph,
At the spoke side I've Cisco 2911 router with giga interface and at the hub side I've a Cisco 7204 and planning to migrate to a 3945 with E1 at now I've 22 spokes.
thanks,
Alcides
Disclaimer
Posting
One potential problem - your hub's E1 provides less bandwidth than the aggregate for your 22 spokes at 128K each.
Disregarding that, on the spokes you might try:
interface tunnel #
qos pre-classify
interface gig #
traffic-shape rate 115000
And on the hub:
policy-map shape4spoke
class class-default
shape average 115000
fair-queue
interface tunnel 1
service-policy shape4spoke output
interface tunnel 2
interface tunnel 22
Hi Joseph,
whats is the equivalent command for cisco 2911 series ("traffic-shape rate") I only found "rate-limit" should I use this command if so can give 2 example 1 for 128K and another for 1M.
best regards,
Alcides
Disclaimer
Posting
No longer supports traffic-shape, eh?
policy-map Shape128K
class class-default
fair-queue
Apply on either your tunnel interface or physical interface, if on physical, and using tunnel(s), add qos pre-classify to tunnel interface.
For 1Mbps, just use 900000 instead of 115000.  (NB: I'm shaping 10% slower to allow for L2 overhead; adjust as you need.)
Hi Joseph,
I tried the configuration you proposed but I still have peak or traffic going under 1Mbps that is the link capacity.
BRANCH
policy-map Shape
class class-default
  shape average 900000
  fair-queue
interface Tunnel1
description ### CONNECTED TO HUB ###
bandwidth 1024
ip unnumbered GigabitEthernet0/0.100
ip mtu 1400
ip wccp 62 redirect in
ip nbar protocol-discovery
ip tcp adjust-mss 1360
load-interval 30
qos pre-classify
keepalive 10 3
tunnel source GigabitEthernet0/2
tunnel destination
service-policy output Shape
HUB
interface Tunnel104
description ### TO BRANCH ###
bandwidth 1024
ip unnumbered FastEthernet0/0
ip mtu 1400
ip route-cache flow
ip ospf cost 1
qos pre-classify
keepalive 10 3
traffic-shape rate 900000 21600 21600 1000
tunnel source
tunnel destination
Disclaimer
Posting
Actually, on the branch, suggested the shaper be placed on the physical interface, not the tunnel.
What exactly are you graphing?
Hi Joseph,
As you suggested i put the policy is now applied to the physical interface
3009-WRT-01#sh policy-map int gi0/2
GigabitEthernet0/2
  Service-policy output: Shape
    Class-map: class-default (match-any)
      1032257 packets, 186339843 bytes
      5 minute offered rate 282000 bps, drop rate 0 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops/flowdrops) 0/725/0/725
      (pkts output/bytes output) 1031532/186438067
      shape (average) cir 900000, bc 3600, be 3600
      target shape rate 900000
      Fair-queue: per-flow queue limit 16
and for graphing I'm using Netflow application.
best regards,
Alcides
Disclaimer
Posting
Sorry, guess I wasn't clear.  When I asked what you're graphing, I meant what interface(s).  Hub, branch, tunnel and/or physical?
Hi Joseph,
I'm graphing the tunnel interface at Hub site.
here the output of the show policy-map
BRANCH-WRT-01#sh policy-map interface gi0/2
GigabitEthernet0/2
      14262051 packets, 2309578882 bytes
      5 minute offered rate 49000 bps, drop rate 0 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/6292/0/6292
      (pkts output/bytes output) 14255758/2319210198
best regards.
Alcides
