Traffic Limiting Problem
Hi guys,
im trying to limit my bandwidth to my servers. Heres my test setup.
FTP Server ----e0/0 Router e1/0----- PC
MY Pc is trying to upload on the FTP Server. I want to limit the bandwidth to only 32 Kbps.
here's my config
class-map match-any FTP-Server
match access-group 10
policy-map FTP128
class FTP-Server
police 32000 1000 conform-action transmit exceed-action drop
interface Ethernet1/0
description ToServer
ip address 10.10.10.1 255.255.255.0
half-duplex
service-policy input FTP128
access-list 10 permit 10.10.20.2
access-list 10 deny any
But the problem is all my traffic goes to the class-default not conforming on my policy. Here's the output of trying to upload some files on my server.
Router#sh pol int
Ethernet1/0
Service-policy input: FTP128
Class-map: FTP-Server (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group 10
0 packets, 0 bytes
5 minute rate 0 bps
police:
cir 32000 bps, bc 1000 bytes
conformed 0 packets, 0 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
drop
conformed 0 bps, exceed 0 bps
Class-map: class-default (match-any)
6452 packets, 9467950 bytes
5 minute offered rate 42000 bps, drop rate 0 bps
Match: any
The traffic is on the class default. I just want to limit the upload bandwidth to 32Kbps. What im missing here =(.
tnx
jeff
Purple
Re: Traffic Limiting Problem
Jeff,
Is the FTP server's IP address 10.10.20.2 ?
If so, change the ACL to match that address as the destination:
match access-group 101
access-list 101 permit ip any host 10.10.20.2
Pls do remember to rate posts.
Paresh
Paresh,
Yes my FTP Add is 10.10.20.2. After changing my acl. I cant upload any more =(
Here's the output.
Router(config-cmap)#do sh pol in
Ethernet1/0
325 packets, 105797 bytes
5 minute offered rate 1000 bps, drop rate 1000 bps
Match: access-group 101
5 minute rate 1000 bps
police:
conformed 266 packets, 16471 bytes; actions:
transmit
exceeded 59 packets, 89326 bytes; actions:
drop
conformed 0 bps, exceed 1000 bps
14802 packets, 21955532 bytes
Match: any
Purple
You might be better of shaping the traffic on the interface leading to the server so that you get better performance than policing, which simply drops all non-compliant packets..
Paresh
hi pkhatri,
what commands are associated with these ?
thanks.
Hi Paresh,
after changing the burst bytes to 4000 somehow it works. though my du meter is saying that im having around 24,26,48 Kbps traffic (changing). How can i determine the best burst bytes for these ? is this normaol changin traffic (24,26,36,48Kbps)?
tnx
Purple
Try the following - apply it on the interface that connects to the server.
policy-map FTP128
class FTP-Server
shape average 32000
interface Ethernet0/0
service-policy output FTP128
Pls do remember to rate posts that help.
Paresh
hi paresh,
somehow they have the same effect, but what are the differnce ? if all of the bandwidth is used by my first upload, what will happen if another connection will attempt to connect ? will this be disconnected ? any idea to share the bandwidth if two connections are there ? or bandwidth sharing per connection ?
tnx
Purple
Jeff,
Shaping buffers the traffic so you should end up getting a slightly better response.
It is really impossible to predict the exact ratio each flow will get when you have multiple flows. However, the second flow will not be disconnected at all - it will simply share the available bandwidth with the first flow. On average, each flow should get a roughly equal share of the bandwidth.
Paresh
Hi guys,
Just to continue my query here. I've been testing my setup and it seems that traffic shaping works only on one bandwidth ?
here's my testing
FTP Server -- [e0/0 Router e 1/0] -- FTP client
First Test: Upload - 64Kbps
Upload file from FTP Client to FTP Server
BW = 60-70Kbps = OK
Second Test: Download - 32
Try to download a file simultaneously with the uploading
Effect:Suddenly my Upload Speed was down to 8Kbps.
How come my Inbound/Outbound is affected since i declared two policy for Uploading/Downlaoding ?
Purple
Hey Jeff,
Could you pls post your config ?
Paresh
Hi Paresh,
Glad to see you replied. Im trying now to configure upload/download speed. I'm trying to upload at 64K and work perfectly. But when i try to download simultaneously, my upload speed digrades. How come? I want them to be independently configured to different speed without affecting each other.
Here's my config.
class-map match-any FTP-Server-Upload
class-map match-any FTP-Server-Download
match access-group 102
policy-map FTP-16-Download
class FTP-Server-Download
shape average 16000
policy-map FTP-64-Upload
class FTP-Server-Upload
shape average 64000
description FromUser
ip address 10.10.20.1 255.255.255.0
full-duplex
service-policy output FTP-64-Upload
half-duplex
service-policy output FTP-16-Download
access-list 102 permit ip host 10.10.20.2 any
Thanks.
Jeff
Purple
Thanks Jeff,
Could you also post the output of 'show policy-map interface eth0/0' during the middle of your test ?
Paresh
Purple
One more question: do you also see this happening when you remove the download policy and then initiate a download while an upload is in progress ?
Paresh
Hi Paresh,
Here's the output. My Upload speed right now is only 24Kbps and download speed is 12 Kbps. thanks for helping, i just want to test it first before deploying.
Ethernet0/0
Service-policy output: FTP-64-Upload
Class-map: FTP-Server-Upload (match-any)
6147 packets, 5583865 bytes
5 minute offered rate 17000 bps, drop rate 0 bps
5 minute rate 17000 bps
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
64000/64000 2000 8000 8000 125 1000
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 6147 5583865 899 1277938 no
429 packets, 40393 bytes
Match: anyEthernet1/0
Service-policy output: FTP-16-Download
Class-map: FTP-Server-Download (match-any)
10946 packets, 8766710 bytes
5 minute offered rate 15000 bps, drop rate 0 bps
Match: access-group 102
5 minute rate 15000 bps
Traffic Shaping
16000/16000 2000 8000 8000 500 1000
- 5 10960 8774504 9180 8640807 yes
1007 packets, 94427 bytes
Match: any
Thanks.
Jeff
Purple
Jeff,
You might want to configure 'load-interval 30' under both of your interfaces so that you get more accurate rates displayed by these commands - the 5 minute moving average is far too slow.
Now, I see that the outbound policy on eth0/0 shows an offered rate of only 17000 bps - your PC itself is only presenting that much traffic so the router can't really carry more than that.
Still awaiting the answer to the second question I posed to you..."do you also see this happening when you remove the download policy and then initiate a download while an upload is in progress ? "
Paresh
Hi Paresh,
Sorry for the long delay. I've attended some problems.
What do you want me to test ? Actually when im uploading and downloading, the bandwidth degrades. When i remove the download policy, suddenly the speed for download moves up to 1Mbps which took only some 2 secs for my download. What test would you want me to take ?
Purple
Here's what I was after:
- remove the download policy
- leave the upload policy in place
- ensure 'load-interval 30' is configured on your interfaces
- start your upload
- start your download
- get 'show policy-map interface' output
- post the above output :-)
In fact, you might want to then repeat the above test with the download policy applied - the difference from your previous tests is the load-interval setting..
Paresh
Hi Paresh,
I've tried configuring both the same speed and look at the results.They are the same.Ill try to trim down the speed of the other one.
Ethernet0/0
Service-policy output: FTP-32-Upload
1179 packets, 951573 bytes
30 second offered rate 32000 bps, drop rate 0 bps
30 second rate 32000 bps
Traffic Shaping
32000/32000 2000 8000 8000 250 1000
- 2 1177 950005 794 530703 yes
37 packets, 3464 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: any
Ethernet1/0
Service-policy output: FTP-32-Download
891 packets, 532025 bytes
30 second offered rate 31000 bps, drop rate 0 bps
30 second rate 31000 bps
Traffic Shaping
- 4 908 548173 691 531638 yes
29 packets, 2679 bytes
Match: any
Purple
Jeff,
The key thing to note from your output is that the drop rate for both is 0 bps - that leads me to think that the problem is not your router, but in fact lies elsewhere....
Hope that helps - pls do remember to rate posts that help.
Paresh
Hi Paresh,
So basically my config is correct ? So that i wont be messing with the config. I'll try to look at the other equipment like the client.
Thanks.
Jeff
Purple
Yep, that's my thinking. If the router was messing about with these packets, you would see drops.. But since you don't see any, I would look at other elements first.
Pls do remember to rate posts that help...
Paresh
316
