Traffic Monitoring Graph on Interfaces ??????
i have config MRTG 2.12.2 for the our traffic on 7206 VXR.
i want to ask Is there any other efficent software which we can use insterd of MRTG. ????
Silver
Re: Traffic Monitoring Graph on Interfaces ??????
Silver
Try cacti, it's freeware and very good. It can do snmp queries defined by users and also have templates for queries.
http://www.cacti.net
Bye
FCS
Rate me if I helped.
Thanks alot for the quick ressponses
regards
You can try PRTG, commercial version of MRTG.
Silver
correct FCS,
cacti is very good ... cactiEZ is better :)
http://cactiusers.org/forums/topic324.html
Andrea
Hi,,
thanks alots for the replying me ,
I have just try opmange and downloaded it from the given sourse
http://manageengine.adventnet.com/products/opmanager/
very ipressive but want to ask about it , it work online and we have critical machine ,, and we want run it in inside the network ............ not online will work ??
need ur assistanic in this matter plz suggest .
Solarwinds, either Engineer's Ed. or Orion, are good too and decently priced.
Paul
I want to sak about opmanger Engine
i have config it but facing problem with my Dell Machine whibh have OS 2003 server .
I have cross check that SNMP is enable no fire wall on window . but not geting out on CPU DISK and MeM utilization
plz suggest ???
128
