Traffic not showing as Queued under DSL policy-map
exonetinf1nity
Greetings, i have an 2801 router terminating an SDSL connection, i have configured both class maps and a policy map for voice traffic and applied it to the dialer interface, however when i do a "sh policy-map int output" it shows that voice packets are being matched but not queued.
Config and output attatched, would anyone be able to shed any light on why this is happening?
10 Replies 10
lejoe.thomas
Level 3
Level 3
Hi Mark,
Packets are unlikely to queued if the link is not experiencing any form of congestion. Perhaps you could also try reducing the load-interval under dialer interface to 30 (for testing) seconds and post the results of show policy-map interface command.
Lejoe
Joseph W. Doherty
As Lejoe notes, you only see queued packet stats if the class packets actually queue. You class stats do show the packets matching the class criteria.
One possible reason for this, if your physical interface is Ethernet (and it appears to be) and your SDSL offers much less bandwidth, traffic might be unable to hit interface port speed. What you want to do is define a hierarchal policy which shapes the bandwidth to correspond with your SDSL's actual provided egress bandwidth.
Cheers for the replies guys, The only thing that concerns me is that no packets have been matched over the last week, and im confident that the link has been fully utilised during this period.
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 192 (kbps) Burst 4800 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
I have altered the policy as below.
class-map match-any Voice-Media
match ip dscp ef
class-map match-any Voice-Signalling
match ip dscp cs3
match ip dscp af31
policy-map SDSL-WAN-OUT
class Voice-Media
priority 192
class Voice-Signalling
bandwidth 8
class class-default
set ip dscp default
fair-queue
policy-map SHAPE-SDSL-WAN-OUT
class class-default
shape average 1000000
service-policy SDSL-WAN-OUT
interface Dialer 1
service-policy output SHAPE-SDSL-WAN-OUT
Do you think this would be sufficient?
Seems like packets are not marked, you may want to check with an analyzer if indeed they are.
Seems good to me, try also reducing the load-interval to 30 (for testing) under the dialer interface and then take a look at the show policy-map int command.
Lejoe
"The only thing that concerns me is that no packets have been matched over the last week, and im confident that the link has been fully utilised during this period."
I've highlighted, below, you stats that show packets have been matching.
sh policy-map interface output
Dialer1
Service-policy output: SDSL-WAN-OUT
Class-map: Voice-Media (match-any)
2465273 packets, 159838046 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip dscp ef (46)
2465272 packets, 159837980 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Class-map: Voice-Signalling (match-any)
1906714 packets, 109596710 bytes
Match: ip dscp cs3 (24)
1898667 packets, 104347832 bytes
5 minute rate 0 bps
Match: ip dscp af31 (26)
8047 packets, 5248878 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 265
Bandwidth 8 (kbps)Max Threshold 64 (packets)
(depth/total drops/no-buffer drops) 0/0/0
Class-map: class-default (match-any)
6698271 packets, 2259849247 bytes
Match: any
QoS Set
dscp default
Packets marked 6698273
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
Appologies i meant under the "Queueing" section.
Queueing
Strict Priority
As said in earlier posts, if the pkts matched/bytes matched are non zero only when the class experienced coongestion
Have a look at the foll link
http://www.cisco.com/en/US/tech/tk543/tk760/technologies_tech_note09186a0080108e2d.shtml
Narayan
Yes, and as both I and Narayan have mentioned, you shouldn't see any count there unless there's enough interface congestion to cause packets to queue.
Thank you all for your time, it's cleared up any concerns i was having.
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
