Webcast-Catalyst9k
Traffic Policer
I have an ASR 1K.  My ISP provides me with a layer 2 handoff.  When I plug the other end of the cable into my switch I also plug the two ASR routers ports per that provider into this Cisco 3560 switch.  I have 3 metroethernet 50/50 connections.  One particular (Probelmatic) has a policer on their end to cap me at 50 meg on the 100 meg port.  On my ASR I have a policer on each ports that my provider(s) are plugged into to cap me at 50Mbps.  One of my providers are causing the bandwidth to drop dramatically.  They think its due to the policer.  The other two provieders are fine.  Has anyone ever heard of this.  Below is an illustration.
ISP's equipment------------- CPE ----------- My Cisco 3560 switch ------- ASR1k(with policier or all three ports for all three ISPs)
Thanks in advance!
1 REPLY
Super Bronze
Re: Traffic Policer
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Policers can be very detrimental to some traffic flows, generally when they use a too small Tc.
Do you know all the parameters being used by all the policers?
PS:
BTW, I would suggest shaping traffic you know is going to be subject to a downstream rate limiter.
61
