03-26-2006 11:21 PM - edited 03-03-2019 12:11 PM
I am A bit confused about this feature,
what is it supposed to do, cause when I configure the class maps for say ftp and smpt to controll the amount of bandwidth to 56k, and then I do a test the monitoring and debuging show that the packets are conformed and some are dropped. but when you check say ftp download it exceeds the 56k. Does this feature only work when the line is full with other stuff. I have tried also rate-limiting with access-list and still no luck.
any Ideas or real working configurations cause the ones on the net seem not to work properly
costas
03-26-2006 11:46 PM
Ftp download excceding 56K depends upon your configuration. What action u taken for the exceeding traffic ??? did u given drop or permitting with lower precedenc.
If possible pls. post the config.
rgs,
03-26-2006 11:58 PM
what am i suppossed to do when exceeded, I have drop, to keep it stable at 56k what must i put
costas
03-27-2006 12:29 AM
Thatzz again depends upon your requriment. If you strictly want to allocate only 56K to ftp download you should configure drop action for exceeded traffic.
But if you want to allow exceeded traffic if there is bandwidth then you can allow that traffic, might be with less priority!
Rate if it helps,
Rgs,
03-27-2006 12:34 AM
You could use something like the following:
class-map match-any FTP_SMTP
match protocol ftp
match protocol smtp
policy-map LIMIT_FTP_SMTP
class FTP_SMTP
police 56000 1750
interface Serial0
service-policy input LIMIT_FTP_SMTP
service-policy output LIMIT_FTP_SMTP
Hope that helps - pls rate the post if it does.
Paresh
03-27-2006 04:32 AM
I have tried this and it still does not work, does the line need to be full for this to work. Just something I forgot to mention, I have a point to point VPN for this link.
costas
03-27-2006 04:36 AM
That puts a different spin on things... Can you post your config ? Things tend to get a little more complicated with VPNs...
Paresh
03-27-2006 04:52 AM
03-27-2006 05:03 AM
Your config seems okay but the problem is that NBAR does not work over tunnel interfaces .... which means that the 'match protocol ftp' is not working.
If you are limiting traffic to/from a FTP server, I suggest you configure an access-list to match the traffic and use 'match access-group' instead of 'match protocol'....
Paresh
03-27-2006 05:08 AM
I have done that as well, with an access-list. the strange thing is that when i do a show policy map interface,it starts to count in the class map for ftp then it starts counting in the default class-map.
any ideas
03-27-2006 05:10 AM
Did you use an extended ACL with the ftp/ftp-data ports ? That does not work ... because of the dynamic nature of FTP data ports....
You need to match on just the FTP server address without any ports for this to work.
Paresh
03-27-2006 05:20 AM
I have done that too, Is there something special for vpn connections, will the confuration work for non vpn connections
03-27-2006 05:23 AM
Well, you've got me beat... that configuration works pretty well for non-vpn connections....
Paresh
03-27-2006 05:39 AM
Now it does not mark at all in the class map packets.
Its getting worser by the hour
