traffic routing between serial and dsl interface
Hi there
I have a big problem that is on my mind a long time now
The scenario is as simplest as I can 123 be.
1760 with a serial, a DSL and an Ethernet interface
Ethernet on LAN
Serial 2Mbit on x provider with a c class for addresses
DSL with static ip
Internal machines run services on several ports and they have IP
addresses of the serial 2Mbit provider.
What I want to do is:
Route gamming traffic and services on Serial Interface
And everything else (including P2P programs) NATed and on DSL
interface.
No my thoughts:
In order to have services on local machines working and accessible from
the outside world I think I must 'ip route 0.0.0.0 0.0.0.0
Serial0/0'.
The classification of the traffic must be based on gamming traffic and
services.
Witch I have a working list of all games ports and is working great on
another location.
Trying to specify everything else except gamming is madness.
So how can I route everything except gamming traffic to the DSL
interface and allow gaming traffic from the 'default' Serial
interface?
Notice that I am pretty familiar with Policy Based Routing and all
those stuff, but this kind of scenario drives me crazy.
Maybe an access-list that allow all traffic and deny gaming and
services, and use this access-list to a route-map and 'set interface
Dialer1' and then attach this route-map to Ethernet interface.
So everything that permitted by access-list will be routed to Dialer1
... NATed and out on the internet.
And everything that is denied by the access-list will be routed on the
default route through Serial interface.
And requests coming from the outside world on the serial interface will
be go to local machines directly and services will operate nicely.
Do you think this scenario will work? Is it worth trying it?
Anyone has any other better idea?
i attached my current config.
Thanks in Advance
Nikos
Anonymous
N/A
Re: traffic routing between serial and dsl interface
I think your suggestion is the most suited one. The scenario suggested by you will work fine , I believe. At the same time, be clear about where to apply Natting and what to translate.This will give you a clear sketch in advance for doing the configuration..
ok now i have made the folowing config.
IOS (tm) C1700 Software (C1700-SY7-M), Version 12.2(15)T16, RELEASE SOFTWARE (fc2)
System image file is "flash:c1700-sy7-mz.122-15.T16.bin"
Building configuration...
Current configuration : 5469 bytes
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
service sequence-numbers
hostname router
boot system flash c1700-sy7-mz.122-15.T16.bin
logging queue-limit 100
logging buffered 4096 informational
enable secret 5 xxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxx
username xxxxxxxxxxxx privilege 7 secret 5 xxxxxxxxxxxxxxxxxxxxx
ip subnet-zero
no ip source-route
ip gratuitous-arps
ip wccp version 1
no ip bootp server
ip cef
interface FastEthernet0/0
ip address 212.x.x.x.x.255.128
ip nat inside
ip route-cache policy
ip route-cache flow
ip policy route-map PBR
speed auto
full-duplex
no cdp enable
interface Serial0/0
ip address 62.x.x.x.255.255.252
fair-queue
no cdp enable
interface ATM1/0
bandwidth 1024
no ip address
no atm ilmi-keepalive
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface Dialer1
bandwidth 1024
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
fair-queue
no cdp enable
ppp authentication pap chap callin
ppp chap hostname xxxxxxxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxx password 7 xxxxxxxxxxxxxx
ppp ipcp dns request
ppp ipcp wins request
hold-queue 224 in
ip nat inside source route-map D1 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0
no ip http server
logging trap debugging
logging facility local2
access-list 1 permit 212.205.83.128 0.0.0.127
access-list 10 permit 212.205.83.128 0.0.0.127
access-list 120 permit udp any any eq 4000
access-list 120 permit tcp any any eq 4000
access-list 120 permit udp any any range 6112 6119
access-list 120 permit tcp any any range 6112 6119
access-list 120 permit tcp any any eq 3724
access-list 120 permit tcp any any range 6881 6999
access-list 120 permit tcp any any range 2025 2035
access-list 120 permit udp any any range 2025 2035
access-list 120 permit tcp any any eq 22
access-list 120 permit igmp any any
access-list 120 permit icmp any any
access-list 120 permit tcp any any eq 2025
access-list 121 deny tcp any any eq 2025
access-list 121 permit ip any any
dialer-list 1 protocol ip permit
no cdp run
route-map PBR permit 10
match ip address 120
match interface FastEthernet0/0
set interface Serial0/0
route-map PBR permit 20
match ip address 121
set interface Dialer1
route-map D1 permit 1
match ip address 10
match interface Dialer1
alias exec spc show proc cpu | exclude 0.00
no scheduler allocate
end
whith this config everything works great ports on access-list 120 go out from serial interface and everything else goes out from Dialer1.
but still the main problem remains.
i have several machines on my internal lan running services and i cant access them with theyr real ip
Serial interface routs a masked c class and dialer interface has only one ip and needs nat.
what is the solution here
where is the nat problem?
Thanks in advance
Nikos
99
