Webcast-Catalyst9k
traffic shaping
We would like to limit the portion of our outbound (serial0) bandwidth used by a particular server. We want to create an access list group containing that server's IP address, and then put that access list group into a traffic shaping statement. Can anyone provide an example of the commands necessary to implement?
1 ACCEPTED SOLUTION
VIP Purple
Re: traffic shaping
basically, you have a couple of options to accomplish this. Let's say your server has IP address 192.168.1.1, and you want to limit the bandwidth to 200K on your serial interface. Let's also assume that your WAN link has 512K of bandwidth available.
Your configuration would look like this:
interface Serial0
bandwidth 512
fair-queue
traffic-shape group 1 200000 250000
access-list 1 permit 192.168.1.1
Or you could simply rate-limit on your serial interface:
interface Serial0
rate-limit output access-group 1 200000 4000 6000 conform-action continue exceed-action drop
Another alternative would be to use CBWFQ:
class-map match-all LIMIT
match access-group 1
policy-map SERIAL
class LIMIT
bandwidth 200
interface Serial0
service-policy output SERIAL
Can you try any of these configs and see if that works for you ?
GP
Re: traffic shaping
if you want to configure a kinda limiting only then would suggest to check out for CAR (rate-limit).
You can achieve the limiting in conjuntion with the ACLs with the rate-limit statement.
do refer these links for more on both CAR and shaping..
http://cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca594.html
http://cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800bd8ef.html
regds
VIP Purple
Re: traffic shaping
interface Serial0
bandwidth 512
fair-queue
interface Serial0
policy-map SERIAL
class LIMIT
bandwidth 200
interface Serial0
GP
Re: traffic shaping
I've implemented the first option, we'll keep an eye on it during peak time and see what happens.
Thanks for your help.
Re: traffic shaping
HI
Curious to know which of the two option suggested by George above are recomended. I think rate limit will simply drops the access packets (which may be good for security related implimentaiton) where as the 2nd option of limiting the BW may delay the packets going thr' the interface. (packets may be queued upto some extent). This may make difference for application traffic which is being shaped.
200
