Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Translate TCP to x.25 issue
I'm translating TCP to x.25 on a Cisco 3640 router.
Every time a 0D or 8D character is sent in the application layer it is translated to a real carriage return creating multiple x.25 packets.
Does anybody know how to make this translation transparent ?
I'm using the following command :
Translate tcp 192.168.1.1 port 10000 stream x25 1262625 quiet.
Thanks in advance.
Re: Translate TCP to x.25 issue
Chris,
Try changing the default x29 profile as follow:
x29 profile default 3:0
This should fix the issue.
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Thanks for your response.
But the x29 profile configuration doesn't fix the issue.
Note however that this is not about an inbound x.25 connection. The TCP socket is translated to an outbound x25 connection.
Adding the swap option to the translate command solved the issue.
Thanks for the support !
184
