01-06-2009 07:57 AM - edited 03-04-2019 03:21 AM
Hello guys,
I have a 28xx Router. 2xT1/s are connected to its serial interfaces. I bundle them in a PPP Multilink interface. I am using Solar winds software to monitor the device. Lately I am getting a lot of transmit discards errors for the Multilink interface and I am sure they are not related to the traffic volume. Can anybody tell me why I am getting these errors on the router?? Let me know if you need output from any âshowsâ command. Thank you in advance!
rvr
01-07-2009 04:19 AM
So, nobody can help on this issue??
rvr
01-07-2009 05:53 AM
Do you see transmit dicards on the multilink interface alone or also on the serial interfaces as well?
What is the IOS you're running on the router
Sh interface output along with the interface configuration would help
Narayan
02-12-2009 07:58 AM
My Solarwinds is reporting the same problem but only on the multilink interface. The sho int mu does not report any errors or drop. the router is a 2811.
03-21-2011 10:05 AM
I'm getting the same problem on a Cisco 1941. SolarWinds is reporting thousands of discards but interfaces on both ends are clean, however there is a shaping policy attached to the outbound interface on our edge router. Would the shaping policy discard traffic and not report to the interface output?
