Community Member
Transmit discards on 28xx Router
Hello guys,
I have a 28xx Router. 2xT1/s are connected to its serial interfaces. I bundle them in a PPP Multilink interface. I am using Solar winds software to monitor the device. Lately I am getting a lot of transmit discards errors for the Multilink interface and I am sure they are not related to the traffic volume. Can anybody tell me why I am getting these errors on the router?? Let me know if you need output from any “shows” command. Thank you in advance!
rvr
Community Member
Re: Transmit discards on 28xx Router
So, nobody can help on this issue??
rvr
Do you see transmit dicards on the multilink interface alone or also on the serial interfaces as well?
What is the IOS you're running on the router
Sh interface output along with the interface configuration would help
Narayan
Bronze
My Solarwinds is reporting the same problem but only on the multilink interface. The sho int mu does not report any errors or drop. the router is a 2811.
Community Member
I'm getting the same problem on a Cisco 1941. SolarWinds is reporting thousands of discards but interfaces on both ends are clean, however there is a shaping policy attached to the outbound interface on our edge router. Would the shaping policy discard traffic and not report to the interface output?
871
