04-11-2006 09:56 PM - edited 03-03-2019 12:22 PM
hi,
I have several questions (I'm using cisco 1760 router with a VWIC-2MFT-G703 on each site A and B):
Is it possible to aggregate the two G703 links with transparent bridging ?
I have VLAN with STP on each site. Will the 802.1Q frames be forwarded through the "aggregated" E1 links ?
how can I make the aggreagation : Multilink PPP or bridge-group circuit ?
If you have a sample config, thanks to post it.
thanks in advance.
04-11-2006 11:43 PM
Not sure with the G703 and aggregating them with bridging but the 802.1Q frame will not propagate to that E1 link aggregated or not.
04-12-2006 12:46 AM
So do you know another way I can use to interconnect to remote ethernet LAN with the following prerequisite :
- Two cisco router 1760
- Two E1 G703 interfaces on each router (for redundancy and load balacancing).
- VLAN (802.1q) and spanning tree on each site
- We don't want to use a routing process between the two remote LAN.
